Springs ok to use ???
Old May 26, 2003 | 10:00 AM
STRYKER's Avatar
OK i am getting the cc306 cam and I already have a set of springs that I bought with the heads that I have. My question is will these springs be too much or will they be ok to use with the CC306. The spring spec's are as follows : They are dual vlave springs with a seat pressure of 135 @ 1.910; Open pressure of 320 @ 1.25 and coil bind at 1.150. I was told that this setup was good up to .650 lift but i just want to make sure that these springs aren't too much for the cc306 cam. Thanks
Stryker
Old May 26, 2003 | 09:02 PM
STRYKER's Avatar
Hmmmm.......
Ok, is there no one here that is experienced enough to answer my question, or does it belong in the Advanced Tech forum ? I already did a search on this but I read for about 3 hours and found a couple fairly close answers but nothing right on the money. So how about it, can anyone tell me if these will be ok to use ?
Stryker
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
