Springs to match cam.
Old Dec 17, 2008 | 05:47 PM
1quikZ's Avatar
Are these springs.....
http://store.summitracing.com/partde...5&autoview=sku
K-Motion 750
enough for this cam
http://store.summitracing.com/partde...8&autoview=sku
cc305
or not enough?
Old Dec 17, 2008 | 11:15 PM
rskrause's Avatar
Moderator
Yep.
Rich
Old Dec 21, 2008 | 09:50 AM
1quikZ's Avatar
Originally Posted by rskrause
Yep.
Rich
any probloems with these, seems to be mixed reviews via search?
Old Dec 21, 2008 | 10:15 AM
rskrause's Avatar
Moderator
I think they are a decent spring. Not top notch, but not a top notch price.
Rich
Old Dec 21, 2008 | 11:06 AM
1quikZ's Avatar
Rich
cool! thanks a bunch
Old Dec 21, 2008 | 11:35 AM
NightTrain66's Avatar
I would use these instead . . .
http://competitionproducts.com/prodi...p?number=98215
Lloyd
Old Dec 21, 2008 | 11:47 AM
slowride94z's Avatar
whats the max lift on these?
Old Dec 21, 2008 | 11:49 AM
rated at .600 "max lift" but I would use them up to .570 lift and 6300 RPM. They are in the same catagory with the K motions or Crane 99846 single springs.
If you have more lift, more RPM, etc, a good dbl spring or bee hive is a better choice.
Lloyd
Old Jan 19, 2009 | 02:13 AM
1quikZ's Avatar
Is anything else needed for those springs i heard you have to shim them or something? the 750's that is
Old Jan 19, 2009 | 09:53 AM
Stl94LT1's Avatar
More than likely you will need to shim any spring to get the correct installed height.
Old Jan 20, 2009 | 08:47 PM
1quikZ's Avatar
Really....that i did not know. Thanks. What should my installed height be?
Old Jan 20, 2009 | 08:58 PM
rskrause's Avatar
Moderator
The correct installed height is the one that gives the desired seat pressure and still leaves enough height to avoid coil bind at max valve lift.
PublicEnemy1
Apr 7, 2015 12:21 PM
pimpss96
Feb 12, 2015 01:28 PM
LT14LIFE
Feb 9, 2015 09:35 PM
95chwagon
Jan 13, 2015 09:19 PM
