SPLAYED mAIN cAPS
Old Nov 29, 2006 | 11:31 AM
Vicious95Z28's Avatar
SPLAYED mAIN cAPS
When having splayed main caps installed is there certain hardware that pertains to the manufacturer who made the caps or can I order A set of main studs from ARP for splayed caps. Which caps and hardware do you guys have?
Old Nov 29, 2006 | 01:27 PM
WS Sick's Avatar
The caps I have bought only came with the outer "splayed" bolts ,so I used the ARP 2 bolt main stud kit.
Old Nov 29, 2006 | 02:40 PM
Who was the manufacturer
Old Nov 29, 2006 | 06:44 PM
Severous01's Avatar
jegs has a set for 20 bucks. the caps should either come with bolts or tell you which bolts to get...length, diameter and grade.
Old Nov 30, 2006 | 09:07 AM
WS Sick's Avatar
I have bought the Cat and Eagle steel caps, and I have seen the Milodon caps , the freind that had the Milodon caps also used ARP studs.
Formula Steve
Sep 19, 2023 08:31 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
heus
Sep 8, 2015 12:01 PM
