Spittin 'n Sputter'n
Old Aug 8, 2005 | 02:15 PM
Ultra_Dog's Avatar
I need some remote analytical support: (a.k.a. Frist/Schiavo)
I had fired up the car and without a long warm up, I got on the freeway. Stupidly, I accelerated briskly and as the car got up in RPM, it started to miss/spit/cough real bad. I nursed it back home and now it is broke. I can start it, but can't keep it running.
I assumed it was the opti (#4) and did not perform much additional analysis and installed a deltec.
Unfortunately, that was NOT the problem. I am now at the crux of believing I may have a broken valve spring (had that problem before too!).
Your "Senate Majority Leader" analysis is requested....(although I am a mutton-head, I am not brain-dead).
Old Aug 8, 2005 | 03:01 PM
joeSS97's Avatar
Re: Spittin 'n Sputter'n
Pull the valve covers and look.I would also check your fuel pressure.If it isnt those...check the coil,wires ICM.
Old Aug 8, 2005 | 06:14 PM
blown94's Avatar
It could still very well be your opti. The delteq setup still requires the signals from your opti to tell the coils when to fire. If you had a bad opti b4 the installation it still will not run right. Delteq setup just removes the high voltage side of the optispark. A functioning optispark is still neccessary for the delteq to run correctly. Sounds like you need to get yourself a "back half" of the opti, you dont need the whole distributor. You can of course buy the whole distributor then sell the cap and rotor though. I bought a reman from a local parts store and it was just the back half for like $150.
Old Aug 12, 2005 | 05:36 PM
Ultra_Dog's Avatar
Problem found: Broken Valve Spring.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
