Spinning one tire?
Old Dec 23, 2003 | 01:01 PM
kgkern01's Avatar
Spinning one tire?
My car has become more amt to spinning the wheels, especially on slick surfaces, but I believe it is only spinning the right hand wheel. Am I correct in assuming that my diff is going out? Is it worth it to just go ahead and get a Torsen take off to replace it? With addition of 4.10's of course
Old Dec 23, 2003 | 01:09 PM
GreenDemon's Avatar
Yeah it sounds like your diff is toast.
I don't think 4.10s will solve your traction problems, tho.
Old Dec 23, 2003 | 09:37 PM
my94blackz's Avatar
Agg the one wheel peel, yep new carrier coming soon.
Old Dec 23, 2003 | 09:42 PM
Josh-'04 GTO's Avatar
On a few occasions, we've seen cars taken cars that one-leg, change the diff fluid, and come out with the posi working again. Of course that only works on cars that have gone too long without a diff fluid change. Not a guarantee, but definitely worth a try if you know it has been a while since the last fluid change.
Old Dec 23, 2003 | 10:47 PM
Trans-Am's Avatar
Just keep saving your money, get a 12 bolt and run that junk puny *** 7.5 inch into the ground. Not worth rebuilding it in my opinion if you plan further performance upgrades. That or find a used carrier for the time being. ~~~rob
Old Dec 23, 2003 | 10:54 PM
kgkern01's Avatar
I don't plan on drag racing the car, and if I do it will be on street tires, so I'm not worried about breaking the rear right now. I want to setup more for handling/autox, so because of that and cost of 12 bolt, it won't be happening till a LOT of other stuff is done to the car. I'll try the fluid change with maybe 2 tubes of GM additive, see if that helps any. I do have a slight leak at the pinion seal, so I'll try that first. If that don't work, I will be saving up next for 4.10's, installation $, and either take-off Torsen or T2R if I somehow come up with more money than I expect.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
