speedo jumps a lil when subs hit., please help
Old Mar 2, 2004 | 05:15 PM
JJJ93z's Avatar
today on my way home from work i got on the highway and was crusin at 70 and listening to my stereo and every time the subs would hit the needle would jump up a few mph then back down when they let off, i gunned it from 75 to pass a truck and the needle hesitated then rapidly jumped to 81 ? has anyone ever seen this before? how can i fix it? i have had subs in my car for a few years and this has never happened. then only other thing i ve done to it after it came out of storage on saturday was install a bigger 800 watt 2 channel amp. is my speedo electrical? could the bigger amp have n e thing to do with it? it also jumps at any speed like from 25-27 every time the subs hit, then i turned off my stereo and it didnt do it. any he;p would be appreciated thanks
sorry if this thread doesnt belong in LT1 tech
Old Mar 2, 2004 | 06:10 PM
gtheftz28's Avatar
Your alternator might not be pumpin enough juice
Old Mar 2, 2004 | 06:12 PM
convertz's Avatar
Im not sure but the new amp could be drawing too much power. The speedo is electrical. Do your headliughts dim? That is a common problem with big amps.
Post this in the stereo forum and u will probably get more help, and ways of solving ur amp draw problems.
Old Mar 2, 2004 | 06:23 PM
Brundle's Avatar
get a cap to build up some extra juice in. otherwise u could smoke your battery or alternator after pounding your system for long enough.
been there, done that. not fun at all
Old Mar 2, 2004 | 08:27 PM
JJJ93z's Avatar
thanks for all the help guys , i didnt mention to say that i have a 1 farad Rockford fosgate cap, brand new battery ( 2 days old), and new alternator about 2 months old. the headlights really dont dim. how do u move this post to the stereo forum? thanks again guys
Old Mar 3, 2004 | 09:06 PM
JJJ93z's Avatar
i think it might be my alternator ? one of my friends said that the alternators on early 4th gens are pretty weak 80amps (im not sure) can i put a newer style alternator on my car? (110amps)???
Old Mar 3, 2004 | 09:23 PM
JoeliusZ28's Avatar
check your ground.
my friend had a rockford amp in his old minivan, and everytime the bass hit the tach would jump to like 4k (it couldnt reach 4k without blowing up)
I think he just relocated the ground and it fixed the problem.
Old Mar 3, 2004 | 09:30 PM
JJJ93z's Avatar
Originally posted by JoeliusZ28
check your ground.
thanks for the tipi will try that!
Old Mar 4, 2004 | 02:10 AM
Brundle's Avatar
having a stronger alternator definitely wouldn't hurt with that much juice running through it. i cant say if some of the 4 gens alternators were weaker then others but i can tell u this: phone around to shops in your area about having your current alternator built up. it would be a hell of alot cheaper then buyin a whole new one. basically they just re build it with more winds to make it stronger and handle more current.
Old Mar 4, 2004 | 02:29 AM
madhatter's Avatar
I know 94s came stock with 140 amp. I thought 93s either came with a 100, 120, or 140...
Old Mar 4, 2004 | 10:07 PM
besz28's Avatar
i just think that stereo hits like a bomb. and when the base hits it jumps
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
4586
Sep 27, 2015 01:55 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
