speed limiter
Old Nov 1, 2006 | 10:06 AM
  #16
Javier97Z28's Avatar
Moderator
Originally Posted by Sweetred95ta
I don't know if they will with a stock tune. I remember having to let off of mine to let it shift into overdrive. I'd have to look at a stock tune to see.
Interesting... I know I did it a long time ago too, but not sure if it was with a stock tune or if it was with my pcmforless bolt-on tune I had years ago.
Old Nov 1, 2006 | 11:09 AM
  #17
sandman63's Avatar
Nah you can with a stock tune. She will shift into OD in WOT. An by then ur doing around 130 i belive.
Old Nov 1, 2006 | 11:34 AM
  #18
lt1srule's Avatar
cool
Old Nov 4, 2006 | 10:05 AM
  #19
Red95M6Z28's Avatar
Originally Posted by Injuneer
Stock tuning puts the top speed limit in the range of 108-115MPH, depending on year. If you have the Z-rated tires from the factory, the speed limiter is set to 255 stock.
Just to confirm this.....I changed my speedo today and the "misfire" I thought I had happens in 5th gear right at 115mph everytime! Looks like I have a stupid speed limiter!
Old Dec 3, 2006 | 04:49 PM
  #20
1FstFormulaV8's Avatar
I have went 120+ with my A4. I have a 110 speedo. I know my limiter SHOULD be right around 120. I did this without a tune. The only reason why is because when I went to put un a new VSS I had the wrong one. So my speedometer is way slow. I had my friend paste me with '05 Maxima. My 100 was his 130. I'm guessing I have the VSS that's for a different gear. Anyway. it's a nifty little trick, I didn't know until I did it. I just have to keep an eye on my RPM range.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grabbem88
Feb 10, 2015 06:20 PM
94_formula
Jul 20, 2002 11:19 PM
