speed limiter
Old Jul 2, 2006 | 08:33 PM
lt1srule's Avatar
speed limiter
who can disable this for me ..local ill pay em please help im out by speed world in bithlo
Old Jul 2, 2006 | 09:46 PM
user 647483's Avatar
Re: speed limiter
If you don't find anyone local, any basic mail order tune can do that for you and pick up some HP while they are at it
Check out PCMforless.com or fastchip.com
Old Jul 3, 2006 | 09:27 AM
Re: speed limiter
You can remove the speed limiter with a Hypertech Power Programmer..... find a used one (making sure the original owner programmed his PCM back to stock).
Old Oct 24, 2006 | 01:39 PM
Red95M6Z28's Avatar
Re: speed limiter
WWW.MADZ28.COM
Old Oct 26, 2006 | 05:54 AM
mightymouse383's Avatar
whats up lt1srule, how is that spaceshuttle pulling! ya really do need to get rid of that limiter.
Old Oct 26, 2006 | 07:53 AM
teke184's Avatar
yeah isn't there a "budget tune" from ion that is like $75 or something.
x2
www.madz28.com
Old Nov 1, 2006 | 12:14 AM
lt1srule's Avatar
its the limiter on my 95z not the spaceshuttle 94z there is no limit on that beast...
Old Nov 1, 2006 | 07:15 AM
Red95M6Z28's Avatar
I know my speedo is off due to 3:73 gears but I figured out last night that my speed limiter is set at 132mph. Tried it a bunch of times. Couldnt be fuel related at the same exact speed right? Is the PCM seeing 132 or is it seeing less cause it really does know the actual speed?
Old Nov 1, 2006 | 09:18 AM
MyShibbyZ28's Avatar
If you have a Z28 with the 150mph dash then you do not have a speed limiter. Why and how are you going to 132mph? Legally hopefully. If you're hitting 132 with 3.73 then you are probably maxing it out and can't go any faster. At 133mph you are at 4500 rpm with 26" tires, with those gears, in third (1:1). I don't know if these cars go in to overdrive at WOT.
Old Nov 1, 2006 | 09:23 AM
Red95M6Z28's Avatar
Long stretch of open desolate highway
If you're hitting 132 with 3.73 then you are probably maxing it out and can't go any faster..
Well like I said I know my speed is off some. I am hitting 132 in 5th gear. I have another gear to go.
You realize this is a 6 speed car, right?
When I am actually doing 60mph my speedo reads 68. So how fast am I going when my speedo reads 132? More like 120ish?
Old Nov 1, 2006 | 09:32 AM
Stock tuning puts the top speed limit in the range of 108-115MPH, depending on year. If you have the Z-rated tires from the factory, the speed limiter is set to 255 stock.
If your speedo is "off" because of a gear change, the PCM has no way of knowing that. It thinks, based on the pulses its receiving from the VSS, that its going the speed indicated on your speedo.
If you went from 3.42 to 3.73 without reprogramming, you have a 9% error. True 60 = indicated 65.5, true 121 = indicated 132.
Old Nov 1, 2006 | 09:37 AM
I looked at the lt1srule sig, I thought it was an auto.
Old Nov 1, 2006 | 09:38 AM
Javier97Z28's Avatar
Moderator
II don't know if these cars go in to overdrive at WOT.
Just FYI, yes, they do go into OD at WOT. I did it on Monday on an empty stretch of highway.... it was pulling hard too
Old Nov 1, 2006 | 09:40 AM
Now I know, thanks.
Old Nov 1, 2006 | 10:00 AM
Sweetred95ta's Avatar
I don't know if they will with a stock tune. I remember having to let off of mine to let it shift into overdrive. I'd have to look at a stock tune to see.
