Special tool for slp header bolts ????
Old May 7, 2005 | 09:33 AM
Hyperspeed97z28's Avatar
What tool did you guys use to tighten up your slp header bolts that came with the install kit ...
having some major problems.. cant get to em ???
97 z28 with 96/97 slp headers with slp install kit ... them stupid bolts...
Old May 7, 2005 | 10:32 AM
1stz28's Avatar
Re: Special tool for slp header bolts ????
I used a 12 point box wrench that I ground down a little so it would fit the ones that were close to the header.
Old May 7, 2005 | 10:04 PM
BigJustinZ28's Avatar
ditto , been thru two modded wrenches
Old May 8, 2005 | 08:29 AM
so how did you guys mod them ??
what did u use to grind em down???
Old May 8, 2005 | 11:51 AM
96KillaZ's Avatar
i just used a regualer 3/8th wratcheting wrench... and a couple days later, I was done
Old May 10, 2005 | 10:41 AM
yeah im sure it took a COUPLE of days, lol
Old May 10, 2005 | 11:21 AM
mastrdrver's Avatar
The only two tools you need is a wratching wrench and a 90* offset wrench. With those two tools I did all my bolts. There were a few that are easier from the bottom, but they all can be done from the top with those two tools.
Old May 10, 2005 | 12:11 PM
Thanks!!
We'll have to get these 2 things !!!
Old May 10, 2005 | 01:08 PM
mastrdrver's Avatar
Originally Posted by Hyperspeed97z28
Thanks!!
Not a problem. With those two tools and a third hand, you'll endup thinking that those tools were made for those headers.
Old May 10, 2005 | 03:00 PM
where did you get the tools at ??
Old May 10, 2005 | 03:38 PM
mastrdrver's Avatar
Craftsman: Deep offset wrench and Reversable ratcheting wrench
Not the right sizes, don't remember, but I believe that Sears created those tools for the SLP headers.
Old May 10, 2005 | 07:40 PM
Thanks !!!
Old May 11, 2005 | 12:30 PM
bt96ss's Avatar
I used a craftsman pro boxend wrench for some and a 1/4 drive socket for others. The trick is to start them all by finger then tighten each on thill they all pull up together. The first time I install SLP's I got the first and last in and tightened them then tried to do the others it was way harder this way. Had same problems getting the tools past primary tubes.
jim88iroc305
Aug 13, 2002 09:24 PM
ScottZ
13
Aug 2, 2002 11:45 PM
Wilson
Jul 21, 2002 05:08 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
