SPEC clutch install help...
Old Apr 24, 2003 | 05:58 PM
aozame's Avatar
Question SPEC clutch install help...
Need some installation instructions (ASAP):
what is torque spec for pressure plate to flywheel screws? flywheel to crankshaft screws?
safe to reuse old fasteners?
what is the break-in procedure? i am upgrading to a Stage 3 carbon disc...
thanks!
Old Apr 25, 2003 | 12:04 PM
aozame's Avatar
Old Apr 25, 2003 | 12:20 PM
gb95zconv's Avatar
Flywheel/flexplate bolts...74 ft-lbs
PP bolts.....22 ft-lbs
Reuse the bolts if they are in good condition.
Break in...... take it easy the first 400 miles.....this is pre SPEC
Old Apr 25, 2003 | 01:22 PM
Beast96Z's Avatar
haynes manual says 32 ft lbs. for PP.
Old Apr 25, 2003 | 02:47 PM
gb95zconv's Avatar
My source is the Helms GM service manual.....
Old Apr 25, 2003 | 09:38 PM
97 RedSS's Avatar
LOL..I believe the Chiltons says 14ft lbs...I think I torqued mine to 20-25ft lbs and put alot of loctite on the bolts..
Cody
Old Apr 25, 2003 | 09:47 PM
mr diabolical's Avatar
Cody
yep, loctite on pp bolts will save BIG headaches in the long run. trust me, ive found out the hard way a while back...
Old Apr 25, 2003 | 10:03 PM
Dave88LX's Avatar
I've been told it's good to put anti-sieze on the bell-block bolts as well.
I read somewhere that you shouldn't re-use the bolts if they've been torqued down more than 2 times...cheaper insurance to just get some new ones. I'm sure they'll be fine, and I forgot where I read that.
Old Apr 26, 2003 | 08:56 AM
gb95zconv's Avatar
That should do fine....I did leave out the loctite thing though....deffenetly use it on the pp bolts and the driveshaft yoke bolts.
DirtyDaveW
Mar 15, 2015 07:01 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
