Spark question
Old Dec 2, 2005 | 02:58 PM
NVRLATE's Avatar
Spark question
How do you check for spark? Car cranks but does not want to start. I have no codes and have good fuel pressure.
Thanks.
Dave
Old Dec 2, 2005 | 03:02 PM
OBE1 95Z28's Avatar
Re: Spark question
Pull a spark plug boot off and hold it about 1/2" from ground (heads, engine block) and look for a spark. Better yet is to buy a spark test tool (< $10). This allows you to adjust the gap and prove that you have a hot spark. I've experienced weak sparks caused by failing coils that would not allow the engine to start.
Old Dec 2, 2005 | 04:49 PM
NVRLATE's Avatar
Re: Spark question
Is this what you're talking about?
http://www.thetoolwarehouse.net/shop/THE-404.html
If so would I have someone turn the engine over while I watch for spark?
Old Dec 2, 2005 | 05:53 PM
OBE1 95Z28's Avatar
Re: Spark question
Yes that's the tool and yes you'll need to turn the engine over to generate spark.
Noenav
Mar 1, 2019 07:38 AM
jasonduaine
Mar 7, 2015 09:44 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
