spark plug reccomendation
Old Oct 8, 2008 | 11:52 AM
firstlast's Avatar
im running stock heat range plugs they are ac delco double platinum and my underhood temps seem to be very high and my exhaust is abnormally hot. i was wondering of i should have a colder plug with the motor in my sig?
if so which plug do you reccommend?
Old Oct 10, 2008 | 10:00 PM
firstlast's Avatar
what yall dont use spark plugs?
Old Oct 10, 2008 | 10:01 PM
mdacton's Avatar
nope
Old Oct 10, 2008 | 10:12 PM
MarcR94v6's Avatar
I'd maybe try 1 step colder for the extra power you are making over stock, though I don't know if it actually has anything to do with underhood temps. But I'm still learning here, so I may be wrong.
A lot of people here like copper plugs for better conductivity over platinums, despite their shorter life verses the platinums.
Old Oct 11, 2008 | 02:16 AM
dStruct's Avatar
I had an complication with a tune a while back and my fans weren't coming on at all and oddly enough it wasn't overheating really with the 160F thermostat but my under hood temps seemed really really hot.
Old Oct 11, 2008 | 06:18 AM
The spark plug heat range isn't going to affect under hood temperatures. Running too hot a plug may contribute to detonation or to burning the electrodes off the plug, but it doesn't control combustion temperature. Taking a quick look at the plugs will tell you if you need a colder plug. But its not going to solve the exhaust temp problem. Excessive exhaust temps are usually the result of running lean. Have you measured the exhaust temp with an EGT sensor?
Old Oct 11, 2008 | 09:58 AM
firstlast's Avatar
the plugs look ok they have a pinkish tint the ground straps are a lil white so it is running lean. but thats why i have the new injectors, mine are maxed out
Old Oct 11, 2008 | 10:17 AM
LaredoZ28's Avatar
I recomend NGK Iridium tr55's for stock replacements and NGK V-power tr6's for a colder plug. I've run both and they both perform very well. the TR6's are more of a Nitrous or forced indutioin plug though.
Old Oct 11, 2008 | 04:08 PM
firstlast's Avatar
i had tr6's and they fouled
Old Oct 11, 2008 | 04:12 PM
LaredoZ28's Avatar
I havnt had a problem with them. was there any thing wrong with the car to make them foul?
Like i mentoined b4 tr6's are more for nitrous or forced induction.
Old Oct 11, 2008 | 04:21 PM
henryz28's Avatar
I am running autolight 106s.
Old Oct 11, 2008 | 06:18 PM
Chuckels's Avatar
I use the NGK tr55's. At 2 bucks a plug its cheap to replace a couple times a year.
Old Oct 11, 2008 | 06:20 PM
mdacton's Avatar
I use those too most of the time or AR103's
Old Oct 11, 2008 | 08:41 PM
MarcR94v6's Avatar
There are better tr55's that cost more and will last longer fyi, they have a few different grades. If you don't want to replace them twice a year that is.
Old Oct 11, 2008 | 08:56 PM
LaredoZ28's Avatar
I believe the better ones are the iridiums.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
