spark plug problems
Old Dec 25, 2006 | 10:55 AM
reamo04's Avatar
spark plug problems
well, finally changin out my plugs/plug wires/cap and rotor, and im having problems getting the passenger side plugs out, or even getting to them
my car has stock exhaust manifolds, any suggestions?
what do i need to move/remove to be able to get to them?
Old Dec 25, 2006 | 12:07 PM
2000GTP's Avatar
I pull #4,6,and 8 from the bottom with some different style extensions and swivels. As for the #2, I do it from the top with the alternator removed.
Old Dec 25, 2006 | 01:12 PM
JP95ZM6's Avatar
I bent a 12 point boxend wrench with a torch to crack one of em loose once. Kind of a Z shape, with the first bend right next to the box. Can't remember which plug, though. Probably #2, since I never pulled the alternator for a plug change.
Old Dec 25, 2006 | 01:56 PM
reamo04's Avatar
haha, i got em all
driver side from the bottom
passenger side from the top
wasn't too difficult
now i just need to do fuel filter
and i didnt pull anything or losen anything
did it w/ y-pipe in place, and alternator in place
Old Dec 25, 2006 | 07:24 PM
LT1_383's Avatar
I find an offset 5/8" wrench to be useful. Have fun with the cap and rotor.
Old Dec 25, 2006 | 10:09 PM
96 TA's Avatar
damn! Ill pay you do do mine then!
Old Dec 25, 2006 | 10:24 PM
reamo04's Avatar
thats one thing im not looking forward to, except im doing an internship at a place that is always working on LT1s (impalas, camaros) that im gonna have help me
plugs took me about 2 1/2 hrs or so and i didnt even bust a knuckle
hardest one was the one right under the alternator
driver side was easy, and the passenger side i got all of them from the top (thank god for small hands and arms)
Old Dec 25, 2006 | 10:44 PM
Kevin Blown 95 TA's Avatar
I use a 5/8 offset and one of those shorty sockets with a 3/4 hex and a closed end wrench to tighten and loosen. To spin them out I use rubber tubing over the ends and maybe a screwdriver in the other end to help twirl it.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
