Shopping List
Old Dec 25, 2006 | 11:38 PM
RyanD's Avatar
Shopping List
January is going to be a big month for the car, I just need some input on what all I'll need. I'll be picking up some LT's, 3.73's, and a gm847 cam. What should I get for the cam as far as springs, locks and all that, should I get new pushrods and lifters, or will stock suffice? I just don't wanna leave anything out, thanks guys!
Old Dec 26, 2006 | 01:03 AM
Critter's Avatar
hardened pushrods, springs, rockers, copper gaskets, o2 extentions, rear end girdle, headers, y pipe or true duals.
just to get you started
Old Dec 26, 2006 | 01:41 AM
seawolf06's Avatar
Copper EXHAUST gaskets, just to be specific. Y-pipe/duals depends on how easy or hard of an install you wanna do. I don't think the gains are much different. Everything else will also depend on your budget. Search around here for each thing and you'll get a wealth of knowledge.
Add to that: guideplates, felpro gaskets, injectors, TUNE, timing chain.
Old Dec 26, 2006 | 01:50 AM
Critter's Avatar
injectors ,fuel pump are optional but would help a lot.
Old Dec 26, 2006 | 01:53 AM
seawolf06's Avatar
Yes, depends if they are limiting you or not. You'll have to check that when you get your tune. Might also want to look into some diagnostic software or a scanmaster.
Old Dec 26, 2006 | 09:59 AM
95LT1conv's Avatar
ditch the copper header gaskets and get a set of felpro 1406's
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Dec 5, 2014 11:42 AM
