spark plug help
Re: spark plug help
Please don't "double post"..... there is no reason to post the same questions on "LT1 Engine Tech" and "General F-Body Tech".... alll you did on "General...." was cause confusion, because you don't have the year of your car in your signature.
Re: spark plug help
Multiple threads makes for confusion, and it makes it harder to find during a search later, anway, the first time i did mine the motor was out, the second time, i did headers and sooner or later im going to have to do them again, I think im going to try and drop the subframe from the car a couple inches, that might give more clearance for 6,8. I did this once before on a caravan and the 3 closest to firewall took less time than the front 3
Re: spark plug help
Originally Posted by saltydog
my car is a 94 formula with a lt1.
the reason i post on both forums is because i get different reponds.
A little friendly advice... its not a good idea, and I'm asking politely that you don't to it.
