Spacer/Washer on Cran (3 bolt adaptor)
Old Jun 21, 2004 | 11:15 PM
ZDriver96's Avatar
I yanked my engine and took it to the shop and am not trying to figure out where some bolts go. So i found the single crank bolt that holds the adapter in. By adapter i mean the thing that you bolt your crank pulley too. But in the center of it i can see where i big fat washer thing went. But it doesnt seem to fit through the bolt.. It'll slide through the threads of the bolt but when it meets the none threaded part it stops.. But u can see that it use to sit down in the crank adapter thingy.. So that fat washer does fit in there right?
Old Jun 22, 2004 | 08:12 AM
The large, thick washer on the crank hub bolt should fit up next to the head of the bolt.
Old Jun 22, 2004 | 02:32 PM
ZDriver96's Avatar
yeah i got it... it was mushroomed in ... ended up taking it to a machine shop to have it drilled out just a bit
Victor Lamb
Aug 26, 2017 02:52 PM
canbaufo
May 17, 2015 10:35 AM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
