soundclip of 224/230 cam?
Old Apr 3, 2004 | 01:34 PM
david97gsxr's Avatar
i've been doing a lot of research on different cams, trying to decide which to get. and while i'm not basing my decision on sound alone, i hear some people say that comp cams 224/230 sounds almost stock, and others say it sounds "beefy" or "insane". i've also heard that the hotcam has a nice lope, and i've heard it doesn't...i'm not really interested in getting a hotcam, but i just want to decide for myself..
so anyone have any soundclips of either cam? or any other cam for that matter?
Old Apr 3, 2004 | 03:11 PM
JustAnotherGuy's Avatar
http://nuke61.homestead.com/files/Ca...eme224_230.wav
http://www.angelfire.com/space2/97_m...es/Formula.wmv
Old Apr 3, 2004 | 03:19 PM
Daryn95Z's Avatar
I'v had a couple of people think I was running the cc306!
Definately sounds good with nice exhaust.
Old Apr 3, 2004 | 03:24 PM
I have a Q about this cam too im planning on using it in my swap.
How much difference between sound and power is there on the 112LSA and 114LSA ?
-matt.
Old Apr 3, 2004 | 05:29 PM
b-stevens's Avatar
-matt.
The same exact question I've been wondering.
Old Apr 3, 2004 | 05:34 PM
DZNUTTS's Avatar
It sounds DAMN good................
Old Apr 3, 2004 | 08:24 PM
Kryckter's Avatar
http://www.students.wtamu.edu/~jy785...0Am%20Idle.wmv
http://www.students.wtamu.edu/~jy785...m%20Launch.wmv
Theres mine with that cam
Old Apr 3, 2004 | 09:05 PM
RichJ's Avatar
I have a 224/230 on a 114 and it doesn't sound as choppy as the sound clip above. It definitely doesn't sound stock though. I get a lot of comments about it not sounding stock at autocrosses, and I have a fairly quiet exhaust. As far as power of 112 vs. 114 LSA, the 112 is going to make better midrange torque and the 114 is going to pull better off idle and probably be close to the same power up top. My best time at the track is 12.2@113. And it passes an emissions test...
Old Apr 3, 2004 | 11:24 PM
b-stevens's Avatar
Did you pass on the first try? With what kind of tuning?
Also, what kind of 60' did you pull on that pass at the track?
Old Apr 4, 2004 | 06:35 AM
RichJ's Avatar
Yes, passed the first try. Stock part throttle tuning. This is on a two-speed IM240 dyno type test.
That was with a 1.69 60-foot.
Old Apr 4, 2004 | 08:38 AM
94droptopz's Avatar
man that sounds sweet
Old Apr 4, 2004 | 08:51 AM
LT1ponykilla's Avatar
I have the same cam but no sound clips. I do believe that the 114LSA will be a little quieter and it will lower the power range of the cam.
rideordie
Nov 5, 2019 04:52 PM
LimitedEd1LE
May 18, 2015 01:24 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Nov 20, 2014 06:03 PM
