son of a ***** - tiny hole in side of radiator-- recommendations
Old Apr 30, 2004 | 11:27 PM
sabre81's Avatar
tonight when i got home i noticed a bit of coolant on the ground. I looked underneath and a little tiny steady stream of coolant coming down. it stopped. started the car again and more coolant coming down.. i finally found a tiny maybe little bigger than a pin sized hile in the side of the radiator neat the battery. It streams out when i squeeze the radiator hose near the battery. I was thinking some jbweld over the hole, is this a dumb idea? recommendations?
thanks
Old May 1, 2004 | 12:11 AM
1msfyter's Avatar
Drain the coolant and sand the hole. Then some JB weld and let dry overnight.
Old May 1, 2004 | 04:49 PM
ChuckZ28's Avatar
Go to autozone and get yourself some radiator sealant. I got the copper stuff. It is important to follow the directions on the back. It is time consuming with running the engine and changing coolant, and letting it dry etc. I think it took me about 8 hours or so but it fixed a nice flowing leak. All the copper particles and glue in the **** clog it up.
Old May 1, 2004 | 06:17 PM
polcat1p's Avatar
when i bough my car there was somr jb weld looking stuff in the same spot on the rad. as your car. So far its been holding up.
Old May 1, 2004 | 07:25 PM
88irocz28's Avatar
Man, my radiator is cracked in the same place too. Right under the low coolant sensor. I took the radiator out, cleaned it up and JB welded the hell out of the crack but it still leaks. I'll just make a habit out of topping the radiator up every other day or so.
Old May 1, 2004 | 08:36 PM
gb95zconv's Avatar
I wouldnt put that crap in my engine.
You could try the JB but it most likely want hold long(temperary fix).....new stock type radiators arnt that expensive.
Old May 1, 2004 | 09:33 PM
dnz28's Avatar
go to some place that welds and im sure they will fix it. if you ask nicely they might even do it for free.
Old May 2, 2004 | 02:38 AM
IslandZ's Avatar
Welding isn't gonna work since it is some sort of plastic at the sides of the radiator.
I used some sorta fiberglass epoxy radiator repair stuff i got from Napa and i used JB weld on the inside it worked perfectly.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
owen66
Nov 30, 2014 04:21 PM
siguy
Nov 27, 2014 10:07 AM
