Somone help please!!
Old Jul 28, 2004 | 11:52 AM
19camaro71's Avatar
Question Somone help please!!
So my car has developed a miss and stumble in low rpms under load. It's an M6 and the miss is noticeable most below 3000rpm. I've done the search and have come up with tests to do for heat related problems, like the ICM, or coil. The problem was there before it was fully warmed up, it had been running 3-5 minutes, temp barely over 100, and it started missing. Do i still do these heat tests? What else do I look for? It has newer plugs and wires. AcDelco platinum tip plugs, ACCELL 8mm wires.
I think that doing these test would be pointless though, its only under load, sitting at idle it is not noticeable... One I'd start driving it to test it, it would warm up anything else really fast.
What do I start with? What could be the problem? Help is appreciated. I'm lost on this one . Thanks
Old Jul 28, 2004 | 10:09 PM
19camaro71's Avatar
Re: Somone help please!!
anyone?
I was driving it tonight and the miss was most noticeable in 3rd gear below 3000 rpm..
anyone have any thoughts?
Old Jul 28, 2004 | 10:14 PM
ScrmngChckn95's Avatar
with those headers, I would check to see if one of my plug wires has been burned through, especially since you say you have the problem on startup. That would be my best guess.
Old Jul 28, 2004 | 10:16 PM
A good way to test this is to drive the car normally and then upshift about two gears sometime during the drive. It should be smooth as glass(although straining a bit). If the car starts shaking really violently, then I bet its those plug wires. The same thing was happening to my car when I bought it.
Old Jul 28, 2004 | 10:21 PM
19camaro71's Avatar
thank you... i will have to try this tomorrow sometime. It's kind of strange, sometimes it will run fine, others, well most of the time it has the skip and miss. but not all the time.
thanks though and i will try this, hopefully it won't die on me... already done that! (with clutch in it died)
thanks again
rob-
ollie-99
Pacific
May 11, 2004 07:27 PM
97zNewb
West South Central
Apr 22, 2004 05:01 AM
my96z
West South Central
Apr 25, 2003 10:53 AM
LT1derful
Mar 31, 2003 03:48 PM
99blackz99
Aug 22, 2002 05:20 PM
