something wrong you tell me
Old Jan 31, 2009 | 09:46 AM
  #16
Originally Posted by Dnsean
sae = 5 is this wht your talking about w/ correction? it was a dynojet as well
SAE is one way of correcting the HP. I doubt is says SAE = 5 because "5" is the smoothing factor applied to make the curves appear less choppy. Has nothing to do with the correction factor.
all was jasper rebuild, grr, except springs, 1.6 full roller rockers, cam. they say its 9.7 compression, headers are pacesetter mid, not the best i know. w/ its ypipe and highflow cat, resinator, then straight 3" pipe all the way back tube y'd in back for dual as we
Not clear from your answer.... what heads does it have? Appears it was a simple "rebuild" with no head work. Is that correct?
Then you put the cam, rockers and springs in it yourself? Did you degree the cam?
Old Jan 31, 2009 | 09:51 AM
  #17
Dnsean's Avatar
cam was put in when engine came back from jasper at shop, if i knew then i would have had a different cam heh, installed at 108 intake center line, lobe separation 112 from what cam spec sheet says.. i bet the heads, are different than stock
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
