Is something wrong with my tranny?
Old May 2, 2003 | 11:44 AM
YellowT/A's Avatar
Exclamation Is something wrong with my tranny?
Okay, when I put the car into gear it always makes a loud clunking sound. It doesn't matter if it is drive or reverse. But when I drive it around it shifts great, very firm and immediate. Is there anything wrong with my tranny? Also, when I take corners sometimes I will hear this clunking sound. Sounds like it is coming from the rearend. Could I need to add anything in the rearend?
Old May 3, 2003 | 08:09 PM
YellowT/A's Avatar
Can nobody help me?
Old May 3, 2003 | 08:24 PM
kcz28's Avatar
it could be your tranny mounts.
I had the same problem.
Old May 4, 2003 | 01:41 AM
fbird95's Avatar
Could be the clutches inside the trans starting to slip at low rpms. they can do this when they start to get old. If this is your problem soon your firm shifts will deteriorate. Just hope it is a tranny mount. Good luck
Old May 4, 2003 | 01:52 AM
94Z & 96SS's Avatar
if it is your tranny mount, you will hear it if you shift at higher rpm's too. And it will come from under your console.
Old May 4, 2003 | 02:17 AM
camaro6's Avatar
Is your car idleing high? That could be the problem. Mine is idleing high at around 1500 and doesn't go down at all when the car is warmed up. When i change gears between drive and reverse, it hard and immediate too. Also about a year ago, my tanny was clunking like yours. I went in and had my spark plugs changed just for a normal tune up. After that the clunking stopped Maybe this could be your problem
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
