Something wrong with A/C...?
Old Jun 25, 2006 | 07:14 PM
FeelTheSpeed's Avatar
I'm not exactly if this is an A/C problem, but ever since I replaced the spark plugs and wires on my car, I turn on the A/C and air won't come through the main vents it all comes through the defrost vents. I tried turning the **** to different settings, but I still get the same result on every setting. I tried it with the heater, and I get the same effect. Has this happend to anyone before? How can I fix this? Thank you for your time.
Old Jun 25, 2006 | 07:39 PM
CSJTA's Avatar
Re: Something wrong with A/C...?
It's most likely a broken vacuum line, look around the right side of the engine compartment for a broken line. Also, there is a vacuum valve that is known to go bad, it is in the same area, right side of engine compartment around the AC box. HTH
Old Jun 25, 2006 | 08:11 PM
would there be a hissing sound coming from that general area? And by right side of engine compartment, do you mean passenger side?
Old Jun 25, 2006 | 08:18 PM
Drowned's Avatar
Yep, same thing happened to me....
Old Jun 25, 2006 | 11:04 PM
awesome! That really sums it up lol....once my car comes back to life I'll check that out asap!! Thanks guys!
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
