Someone told me you can remove the thermostat?? Is this true???
Old Feb 23, 2003 | 04:28 PM
96Z28man's Avatar
I never heard this before. Is this possible??? It sounds like a good thing though, always have water flowing down there.
Old Feb 23, 2003 | 04:38 PM
Grease's Avatar
It can be done but its a dangerous thing to do, there was a thread about this a while back. Just get a 160 degree thermostat if you are worried about your engine overheating.
http://web.camaross.com/forums/showt...ove+thermostat
Old Feb 23, 2003 | 04:49 PM
DjArcadian's Avatar
Removing the thermostat causes the coolant to flow to quickly and it is not cooled correctly in the radiator. For the same reason the temp sensor will show a much cooler reading than the car is actually running. This could cause a blown head gasket even when it appears to be running at 180 degrees.
Sauced
Mar 29, 2015 10:53 PM
BigWil
Mar 29, 2015 12:24 PM
alphaauto
Jan 22, 2015 08:02 PM
