cc305 w/nitrous
Old Feb 23, 2003 | 03:59 PM
maximumvelocity's Avatar
cc305 w/nitrous
Does the cc305 camshaft work well with nitrous? I'm thinking of 150-200 shot. Will this much nitrous be too much for a stock bottom end? BTW the engine is from an impalla SS 96' I believe ( currently in my car). I want the car to sound almost stock, which will be a task with Long tubes and true duals, while being able to kick some serious ***-falt, and have good gas milage.
(Project Sleeper)
Old Feb 23, 2003 | 04:39 PM
Black bow tie's Avatar
The CC305 should be fine with dope. As far as using 200hp shots on bottom end, no problem...it should survive that at least twice! JK- Check out the N20 forum, but I think 100hp (120 max) is a better plan for the stock short block LT-1, there are guys pushing 120-150, but I wouldn't. Also, be prepared to spend about twice what you think on the N20 kit by the time you get fuel pressure safety switch, bottle warmer, window switch, blow down tube, etc. that make the kit more functional and safer. Also know that your cars fuel system isn't up to the task of providing the added fuel over 120 shots require. I'm not trying to discourage you, N20's bitchen, but the guys in N20 forum know best, I don't have my kit...yet.
Old Feb 23, 2003 | 05:06 PM
93m6's Avatar
I've been running a 125 shot for a year now on a stock bottom end with no problem. You should be fine with that as long as you buy all the necessary safety equipment.
Russ95Z28
Apr 23, 2015 01:55 PM
Rich_z28
Mar 19, 2003 03:30 AM
MarcPike94B4C
West South Central
Mar 1, 2003 06:33 PM
pattymelt1285
West South Central
Feb 20, 2003 11:42 AM
langtown77
Dec 20, 2002 11:27 PM
