Someone told me you can remove the thermostat?? Is this true???
I never heard this before. Is this possible??? It sounds like a good thing though, always have water flowing down there.
It can be done but its a dangerous thing to do, there was a thread about this a while back. Just get a 160 degree thermostat if you are worried about your engine overheating.
http://web.camaross.com/forums/showt...ove+thermostat |
Removing the thermostat causes the coolant to flow to quickly and it is not cooled correctly in the radiator. For the same reason the temp sensor will show a much cooler reading than the car is actually running. This could cause a blown head gasket even when it appears to be running at 180 degrees.
