Someone please help, code P0400??? EGR flow???
Old Jul 8, 2004 | 07:51 PM
white97z/28's Avatar
I just recently cut the catalytic converters off my car and 3 days later the SES light comes on, so i figure it is the PCM thinking that the rear cats are not workin on my 97. Just to make sure i went and had it scanned and they said it was a P0400 code which means EGR flow or something. HOW can i fix this and IS IT HURTING MY DRIVEABILITY AND PERFORMANCE??? Someone please give me some info, thank you.
Old Jul 8, 2004 | 08:08 PM
It is because of the loss of backpressure from removing the cats. You will need to have the EGR programmed out to keep from getting the trouble code. Don't think it is hurting performance, but not completely sure.
Old Jul 8, 2004 | 11:50 PM
Hey thanks for the reply. Could i have the EGR and AIR tuned out even when im runnin the stock manifolds. I plan on headers later but now im stuck with them. Can it still be tuned out, any help would be greatly appreciated.
Old Jul 9, 2004 | 11:18 PM
So no one knows if this can be done???
Old Jul 10, 2004 | 12:01 AM
I think what most programmers do, is disable the monitoring of the trouble code. Though the EGR function has some parameters that can be modified to keep it from actually functioning.
timmy39120
May 8, 2015 11:41 AM
1996LT1Z28
Apr 22, 2015 07:56 PM
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
91Bird305
Aug 5, 2002 01:39 PM
