some stupid noise.
Old May 3, 2012 | 05:28 PM
Camaro350z28's Avatar
some stupid noise.
anyone ever hear anything like this? i feel like its narrowed down to waterpump or.. i dunno what else could possibly do this. Mind you i took the belt off and its still doing it
Old May 3, 2012 | 06:48 PM
jloshotz's Avatar
If it sounds exactly the same with no belt, I'd say it's most likely the water pump....don't drive it, if the pump lets loose, not only will you be stuck somewhere, but it may soak your Opti, more $$ then. If you don't have a mechanics stethoscope, get a 2 foot piece of hose, put one end in your ear, the other end behind the water pump...move the hose around; it will become obvious where the problem lies. Report back, and good luck!
Old May 3, 2012 | 08:15 PM
96z28_lt1's Avatar
Re: some stupid noise.
could be opti bearing to though.... I know i had o replace my opti because the bearing seized....
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
Greg88
Aug 24, 2015 07:59 AM
cmsmith
Aug 9, 2015 07:30 PM
