some quick questions
Old Jul 3, 2008 | 01:25 AM
94arcticwhiteM6's Avatar
ok i got my engine out and have torn just about everything down and now i have a couple of questions before i finish cleaning it up and reassembling it.
1. should the dots on the cam and crank sprockets be pointed at each other in order to set at TDC? i thought they should and i thought i had the motor at TDC but the dots were no where near each other so im thinking i may have put it 180 out.
2. how do i get the distributor cap off? it looks like you need a special socket, or am i just stupid?
3. i thought the drive shaft for the distributor was keyed so it only went back in one way, can someone confirm this?
4. should i put the timing cover back on before i put the oil pan on? it looked that way with that seal that is at the bottom of the cover.
i think that is it for now. if i think of something else i will be sure to come back and bug you guys. and the help is always appreciated.
Old Jul 3, 2008 | 07:36 AM
1. The dots will be together at #6 TDC and both at 12 o'clock at #1 TDC. Either is correct. http://shbox.com/1/cam_timing_ani.gif
2. https://www.camaroz28.com/forums/sho...d.php?t=616710
3. You have a 1994? http://shbox.com/1/93-94_opti.jpg
4. The timing cover always goes on before the oil pan, since the pan seals to the bottom of the cover.
Old Jul 3, 2008 | 09:40 AM
dude you rock! thanks for the help.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
