Some Q's on some things.
Old May 21, 2003 | 09:43 PM
Larnach's Avatar
First off, does anybody know how to stop the power steering reservoir leak? It keeps coming through the seal on the cap, and this is my third cap... it gets all over the passenger side strut tower, and its damn annoying, any help would be appreciated.
Secondly, I'm looking to remove the ASR setup, and I assume the ABS will go out the door as well but I would like to keep the cruise control setup.
Does anybody know the parts that I will need to do this, I really don't wanna tear the front end apart yet until I'm ready to rebuild the whole car.
Again, any help would be apprecated greatly.
Thanks!
Old May 21, 2003 | 10:35 PM
Z-Attitude's Avatar
I can't see why you want to get rid of the ASR. You could just get the reversal switch module where it would not come on when you start the car, you would only have ASR when you push the switch. If you over fill the PS reservoir at all it may leak out the cap, also if it is getting too hot, you may need a PS cooler. Hope that helps, Later>>>>>>>
Old May 21, 2003 | 11:42 PM
Larnach's Avatar
Thanks for the reply.
I want to get rid of the ASR because it is more of a nuisance than anything else, plus its in the way in the engine compartment... I can't tell you how many times it has almost put my *** off the asphault.. taking power off when in the rain going around a turn... I'd rather control a slide than have a slide and the throttle kicked back taking weight off the rear end and throwing the car into a spin.
As far as the PS fluid, it's at a normal level, not too high, I don't know why it would be getting so hot and "boiling" over the filler cap?
TRS Andrew
Jul 20, 2015 08:24 AM
Fastbird93
Jun 3, 2015 05:56 AM
rednekrocketeer
Apr 20, 2015 09:17 AM
Fei
3rd Gen / L98 Engine Tech
11
Feb 8, 2003 08:56 AM
