solidroller springs
Old Jun 16, 2007 | 01:06 PM
rock1501's Avatar
solidroller springs
I just bought a cam with about a .700 lift I was wondering what valve springs I should use? The afr ones that came with my heads are only good to .680
Old Jun 16, 2007 | 01:22 PM
95ttoplt1's Avatar
Ask the company you got the cam from.
Old Jun 16, 2007 | 08:14 PM
rskrause's Avatar
Moderator
The above is good advice. If you expect anyone to take an educated guess though, you should post the complete cam specs, supporting components used (especially rocker ratio), valve sizes, and desired/expected rpm range.
Rich
Old Jun 16, 2007 | 08:50 PM
rock1501's Avatar
Rich
264/271 685/656 108lsa
jesel sportsman rockers 1.6
crower hippo solid lifters
comp cams hardened pushrods
valves are: Intake Valve, 2.080" x .050" long, AFR #7018
Exhaust Valve, 1.600" x .050" long, AFR #7057
rpm range will be like say 7200 rpm max and not likely under 4800
converter is a 5200 ati 8" race converter in the th400
Old Jun 16, 2007 | 10:04 PM
Built LT1's Avatar
Mine has K-Motion springs. I don't which ones.
Old Jun 17, 2007 | 08:01 AM
rskrause's Avatar
Moderator
Something in the low 200's on the seat and mid 500-600# open ought to be good.
Rich
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
