solid roller and street use
Old Aug 26, 2005 | 11:28 PM
TCAL95Z's Avatar
Is there a problem with driving a solid roller on the street much?
I hear mixed things about this
Old Aug 27, 2005 | 12:21 AM
1racerdude's Avatar
Re: solid roller and street use
It's idle and low RPM's that destroy them.
If ya get the Crower or Isky pressure oiled lifters ya will be OK. Just don't sit and idle all afternoon while talking to someone.
Old Aug 27, 2005 | 05:01 AM
rskrause's Avatar
Moderator
What he said.
Rich
Old Aug 27, 2005 | 06:50 AM
Red95Formula's Avatar
What does the low idle do to the lifters of a solid roller?
Old Aug 27, 2005 | 07:01 AM
rskrause's Avatar
Moderator
They don't get enough oil.
Rich
Old Aug 27, 2005 | 07:23 AM
oh ok
thanks
Old Aug 27, 2005 | 07:58 AM
And to reinforce what's been said above, I have had no problems with my solid roller, using the Crower Severe Duty Cutaway lifters. Its been 5 years since the engine was finiished, and for the first couple years it was a daily driver.
Old Aug 27, 2005 | 12:29 PM
Kurt Crosbie's Avatar
What does solid roller mean?
Old Aug 27, 2005 | 12:32 PM
1racerdude's Avatar
That they aren't hydraulic.
Old Aug 27, 2005 | 12:37 PM
I'm not exactly sure what hydraulic means either, but if they're solid.... Does that mean that they do not increase size and decrease stiffness due to oil pressure?
Old Aug 27, 2005 | 12:42 PM
1racerdude's Avatar
Correct.
Old Aug 27, 2005 | 12:46 PM
So theoretically.... a hydraulic lifter can retain oil at idle due to oil pressure. However, a solid lifter can only retain oil if the rpm's are up because it cannot create its own oil pressure?
Old Aug 27, 2005 | 12:57 PM
1racerdude's Avatar
There is no oil in the solid to effect its operation.The only oil is passing through to lube the rocker's. It is solid,made from 1 piece of steel, no internal's at all, it doesn't change adjustments by oil it stays the same all the time.
Old Aug 27, 2005 | 01:03 PM
Right, so idling a solid roller is bad because if you're idling and only getting 20psi, the lifters are only seeing 20psi if that.
Old Aug 27, 2005 | 02:50 PM
Unless you engine runs a pressure of 40+psi at 800rpm idle.
