solid motor
Old Dec 1, 2005 | 09:37 PM
99s10lt1's Avatar
solid motor
what would i need to do to make my 96 lt1 a solid roller would ineed to use an electric water pump and remove all the gear driven stuff
Old Dec 1, 2005 | 09:57 PM
Re: solid motor
You can run a solid roller camshaft with the stock water pump. I use the LT4 Extreme Duty timing set. I've seen the same setup support 1,125HP on an 8,000RPM solid roller 383 running 20+# of boost.
cmyname1
Feb 19, 2015 08:38 PM
Nostang 96z
Aug 31, 2002 12:01 PM
guionM
18
Jul 11, 2002 01:45 AM
Dustin's97Z
Nov 16, 2001 09:36 PM
Dustin's97Z
Oct 4, 2001 04:12 PM
