sold my iroc now i have 96 t/a ws6 woes! HELP
Old Jan 9, 2013 | 08:24 PM
  #76
bw_hunter's Avatar
Re: sold my iroc now i have 96 t/a ws6 woes! HELP
Originally Posted by Cbystrack
im telling you, i used a mirror on the drivers side back of the block and it says 43 right next to the gm emblem on the block,
then on the passenger side of the block between 6 & 8 cylinders it says "588"
whats odd is that as said above lt1 true 5.7 will have 327 on it, i infact have 327 on the inside of the timing cover i saw when i replaced the cam..... now had i looked at block casting numbers as well i could have found the issue a long time ago but i (assumed) that seeing the 327 number i was safe with a true 5.7
let this be good info for everyone just in case this happens to anyone else. i will post pics next weekend when i pull the motor to prove it says 327 inside the timing cover on a l99 motor.....
I don't know what you're going on about. The 327 has nothing to do with displacement..it's simply the last 3 digits of the block part number. The timing covers are interchangeable so it's certainly possible that they would have the same part number.
You can only be sure of the part number of the block by looking at the block as anything could be changed in the 15 years since that engine was built. Additionally, since it's in your car and they never came in F bodies, it's possible that the timing cover is from your 5.7 liter engine.
Relax and remember that the car is old and is not stock any more. People will give you good solid advice and are assuming that the car is stock. Don't get exercised with them if the advice doesn't fit your altered car....
Old Jan 9, 2013 | 11:41 PM
  #77
Cbystrack's Avatar
i am talking about inside the timing cover stamped on the block it self, im sorry i should have been more descriptive when i said that. if no one agrees ill post pics with i get the enigne pulled. it amazed me
Old Jan 10, 2013 | 01:29 AM
  #78
popo8's Avatar
Subscribed...
Larry (Popo8) Co-owner
LTXtech.com
Old Jan 10, 2013 | 05:14 AM
  #79
The 327 marking is on the front/drivers side, not under the timing cover, and it's cast, not stamped.
http://www.injuneer.com/images/photo.../newfront.jpeg
Old Jan 10, 2013 | 03:05 PM
  #80
Cbystrack's Avatar
sorry thats right, i could have sworn it was under the timing cover but no your right i remember now its under where the air pump bracket sits. my bad thanks for clearing that up.
chris
Old Jan 10, 2013 | 11:25 PM
  #81
And that's a picture of the 350 block we used to huild my stroker.
Old Jan 17, 2013 | 05:52 PM
  #82
Cbystrack's Avatar
alright i got my new engine today, made 100% it was a 5.7 prior to buying it lol
ill be resealing the intake, timing cover and seals in the AM then pulling the monster powerhouse (joke) 4.3L in the PM.
Anyone want to buy a complete 4.3 with aluminum lt1 heads lol
ill post back when the new engine is in and schreading asphalt
Old Jan 18, 2013 | 01:26 AM
  #83
popo8's Avatar
Good luck!
LTXtech.com
Old Jan 18, 2013 | 09:11 AM
  #84
You actually confirmed its a 4.3 block (odd that it was marked 327 on the front and 4.3 on the side???) and that it had aluminum LT1 heads on it? If that's the case, larger combustion chamber 4" bore heads on a 3.74" bore block that originally had smaller chamber heads would explain why the engine made even less HP that the 4.3L engine was originally rated for - low compression and screwed up quench.
It would be interesting to see what head gaskets were used........
Old Jan 18, 2013 | 04:01 PM
  #85
Guest47904's Avatar
Guest
He didn't really seem to listen to any of us from the beginning. I'd be interested to see if we get pictures of the so called 4.3 that has proof.
Old Jan 19, 2013 | 01:43 PM
  #86
Actually at this point, I suspect the entire thread......
Old Jan 20, 2013 | 02:27 AM
  #87
popo8's Avatar
Re: Re: sold my iroc now i have 96 t/a ws6 woes! HELP
Are u thinking troll?
LTXtech.com
Peytons'z
May 6, 2021 09:25 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
Richardan15
May 30, 2015 08:36 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
HectorM52
Jan 16, 2015 10:21 AM
