soft shift
Old Jul 29, 2006 | 09:19 PM
ncarlson's Avatar
soft shift
changed tb went to 52 now car shifts soft at5200 out of 1st. was 6000 same with other shifts soft and early ?
Old Jul 29, 2006 | 09:57 PM
Critter's Avatar
Re: soft shift
your car shifts off electronics unless you have a mod kit, then its off vacume.
its highly unlikely that its the tb
Old Jul 29, 2006 | 10:11 PM
96capricemgr's Avatar
Re: soft shift
A larger TB should be accomapnied by programming for it because they will soften part throttle shifts unless the tranny has been modified to take away computer control of the shift.
I would be the TB in question is an aftermarket one and the TPS needs to be adjusted that is where the shift point problem is coming from. Guessing you have a mostly stock car?? If so the TB is doing next to nothing for you take it off till you can get the tune and learn how to and have the equipment to adjust the TPS. You need to set the closed throttle voltage to .50-.75 by playing with the TPS and maybe slotting the mounting holes. Might have to drill an IAC bypass for it too this works much better than cracking the blades.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
