So when do you a tune up on an LT1 what do you do?
Old Apr 25, 2004 | 02:13 PM
Cerwin Vega Fan's Avatar
Question So when do you a tune up on an LT1 what do you do?
What do you change on the engine when you do a tune up? I'm thinking plugs, wires, and what else?
Old Apr 25, 2004 | 02:20 PM
ChevyIron's Avatar
I also put in new gear oil in the differental,and usually do a oil change when I do the plugs and wires.Check the O2 sensors visually.I also use that fuel injector cleaner that you spray into the intake clean out the builup of carbon.Then again I am quite the maintance freak What ever the normal time to service the car cut that in half thats me.
Old Apr 25, 2004 | 02:22 PM
Is that cleaner stuff you use called seafoam?
Old Apr 25, 2004 | 02:30 PM
Punkillr's Avatar
Heres my idea of a tune-up....
new spark plugs
spark plug wires
coil & wire
fuel filter
flush coolant
change oil
change differential fluid
Old Apr 25, 2004 | 03:26 PM
"White Knight"'s Avatar
change the filter in the tranny or flush it and the filter
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Nostang 96z
Aug 31, 2002 12:01 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
