So she's finally alive, but not without issues of course (video)
Old Jan 7, 2008 | 07:02 PM
  #31
SS RRR's Avatar
Originally Posted by 526 SS 96
You are a real asset to the community, and a productive participant in this thread.
As are you when badmouthing a technique that has been used for decades.
As stated there are ways to adjust them while the engine is running w/out dealing with an oily mess. Another example is getting a valve cover and cutting it in half so the adjusting nuts are exposed.
The clips do work. I've used them for those w/ mild cams and pro mags. Perhaps you just don't understand how they work?
Old Jan 7, 2008 | 07:54 PM
  #32
greenmachinedriver's Avatar
if you are fairly certain that you set them right i would not adjust running or not. the fact that there is no oil getting to the top end and that the ticking got louder makes me suspect that you have no oil pressure and the lifters bled down.
also i think the original poster understands by now that there are two methods of setting valve lash and that peoples opinions and prefrences are very different.
Old Jan 7, 2008 | 08:23 PM
  #33
showstoppers-96-Z/28's Avatar
Unhappy
Exactly, this always happens with a thread where there is more than one "popular/correct" way of doing things, everyone has their own preference and everyone does things differently, arguing how to set the valve lash is not going to help him get oil to his top end. I've heard HV pumps are junk and lots of builds go with them only to soon regret them stripping the oil pump drive gear. Get ur new sensor in, check the oil pressure, pick a method YOU preffer and reset ALL of ur valve lashes then go from there...no oil coming through the pushrods sounds like bad news (i hate to say). good luck with it, let us know what you find
Old Jan 7, 2008 | 09:22 PM
  #34
95z28man's Avatar
Well thanks a lot for the help so far guys. My oil sending unit SHOULD be here tomorrow, then I will get started. As of now, here is my "potential problem" checklist I have compiled to hopefully get this thing in tip-top shape once again:
1. Replace oil sending unit
2. Adjust all rockers correctly
3. Remove and seal up EGR block off plates (I forgot to seal them before and I recently learned there could be a leak if I don't)
4. Shoot some oil all over the valvetrain before covering up again
If there's anything else you should think I should look into, let me know.
Thanks a lot (pray for me lol )
Old Jan 8, 2008 | 08:52 AM
  #35
pizzi-man's Avatar
the oil sending unit is electrical and no oil to the top end is mechanical. Pull your spark plugs disconnect or unplug your fuel pump via fuse, squirt some oil in your cylinders and install a mechanical oil guage. turn motor over with out plugs with the starter and verify oil pressure. There are 5 parts to the oil pump. Oil pickup, oil pump, oil pump sleeve to oil pump shaft, oil pump shaft, oil pump drive gear.
Old Jan 10, 2008 | 02:30 AM
  #36
sn8ke eatr's Avatar
its so easy.. i dont see the rocker debate as having any point. put em on, snug them down properly, start the motor with the covers off and if theres no tapping.. your good. just dont overtighten them
Old Jan 10, 2008 | 07:22 AM
  #37
dangalla's Avatar
that was the debate, but its over now. to each their own
DETROIT_AREA_00_SS
Sep 13, 2002 07:18 AM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
