So if I get a 160* stat and dont get my pcm reprogrammed what happens?
Old Feb 15, 2005 | 09:27 PM
IrocManiac's Avatar
Just curious...I may be buying a new stat pretty quick and wont be able to afford a repogram of the pcm, at least it isn't looking likely in the nearing weeks. I doubt I'd do this just wondered what would happen. I'm going to probably wait, get a 160* and get a pcmforless tune in the next couple weeks...thoughts? suggestions?
Old Feb 15, 2005 | 09:46 PM
badazzcamaro97's Avatar
Re: So if I get a 160* stat and dont get my pcm reprogrammed what happens?
I did this before my tune, and all I noticed was it lowering temperatures like its supposed to.I dont think there will be anything bad.
Old Feb 15, 2005 | 09:49 PM
IrocManiac's Avatar
friend did it said the same thing, but my question is why do you have to do it if it works without the tune?
Old Feb 15, 2005 | 09:51 PM
ChickenScreamer94's Avatar
nothing bad happens. a tune with a 160 stat can let you advance ignition timing a degree or two and programs the fans to come on earlier.
Old Feb 15, 2005 | 10:02 PM
IrocManiac's Avatar
cool, thats kinda what I was thinking but wasn't sure
Old Feb 15, 2005 | 10:04 PM
phinger23's Avatar
you wont get the full benefit of the cooler system...but it will be ok. the fans are factory programmed at i think 235 or so.
Old Feb 15, 2005 | 11:56 PM
As I said before, you don't have to get a reprogram.
Old Feb 16, 2005 | 12:00 AM
94Z & 96SS's Avatar
I put in a 160 without a program(HPP didn't work when I got it). If you drive in alot of stop and go traffic you will notice the temp go up and down alot. If you mainly do highway driving you probably will not notice anything except for your temp being lower.
Old Feb 16, 2005 | 12:04 AM
SSmoked's Avatar
My car never gets above the second line(200?) I have the 160 thermostat and madwolf tuned my PCM, i love it. Even idleing for 30 minutes it dosint budge.
Old Feb 16, 2005 | 07:54 AM
IrocManiac's Avatar
cool, i'll probably get the 160, get a couple paychecks under my belt and go with a pcm.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
