So I changed my Plug Wires.
Old May 28, 2008 | 07:53 PM
Pandamonkey's Avatar
This is more of a rant, but I figured everybody who comes here would appreciate it more than the clowns in the lounge.
For starters, I got the job done.
It took 5 1/2 hours but it's done. That's me and a buddy working on it!
Holy crap for crap! It sure sucked donkey ****!
1,3 and 5 were easy enough.
7 was totally ridiculous. We managed to route the wire through the stock piece of metal that holds it away from the manifold..........at least I think so - there's no way to know for sure other than my car runs. It's completely invisible.
The entire passenger side I managed to get from the top. Extremely difficult.
We took out every piece of the stock wire looms and ran the wires right where they used to be using ty wraps to keep them in place. I can't believe how they are routed so close to the AC pulley!!! Fawk.
I'm a bit scared that 7 could be slowly burning through since I can't see it.
I put in MSD 8.5's, although I read that they are maybe not the best.
Comments/suggestions/opinions are welcomed.
After
Old May 28, 2008 | 08:20 PM
96' Formula WS6's Avatar
msd 8.5's working great for 10000 miles for me so far. Knock on wood.
Old May 28, 2008 | 08:24 PM
93transam1234's Avatar
i just did cut to fit OTVC wires and plugs on my car after i got home from work, took me a little over one hour.
5 hours is just crazy for 2 people, even with out headers....
So yeah get some headers and the over the valve cover kit next time.
Old May 28, 2008 | 08:48 PM
Well..........we shared 15 beer over that time period........so it may have taken less if we hadn't.
I will definitely get myself some damn headers and to the over the top next time.
Stock manifolds SUCK!!!
Old May 28, 2008 | 09:42 PM
Jazsun's Avatar
I did mine this weekend, and reused hte factory looms w/ 8mm taylor wires, that loom behind the steering pump is probably the biggest pita alive.
Old May 29, 2008 | 08:00 AM
DAVE00's Avatar
Custom cut wires and otvc looms make it way easier than trying to put wires back in the stock retainers/locations. 5 hours is not that unbelievable for his case, but I'm with you as my custom cut wires went way easier and took far less time.
Old May 29, 2008 | 10:28 AM
Jazsun's Avatar
I'd say it took my about 2 hours just to get my 8mm through the passengers side p.s. pump. I was using stock looms because I didnt want them touching straight metal tho.
Old Jun 3, 2008 | 12:00 AM
Hrm..........I wonder if I could have problems now.........since I took out the stock looms.
The 8.5mm wire wouldn't fit in them anyhow but.....now the wires are tight against the metal.
How long could I expect the wires to burn through if too close to an exhaust manifold?
How long do you think it would take to wear through due to vibration?
Highlander
Jan 12, 2020 02:13 PM
blac94Z
Feb 23, 2015 04:29 PM
Jazsun
Dec 29, 2014 12:14 PM
TrouserSnake
Jul 19, 2002 07:47 AM
