So.... got me in trouble advice?
Old Aug 4, 2011 | 11:14 AM
82lt1ta's Avatar
Ok so 400 miles on the new build mostly stock except valve train and cam LT1
Driving to work at about 60-65 mph, hear some clunks and a couple clanks and I felt like I was in a nascar race the way the motor let go, It was possibly the coolest thing I have ever destroyed but now I need to rebuild it again. I'm pretty sure I put a valve through the piston or something, but I will figure that out when I tear it a part.
I am looking at a 383 rotating kit and I found this one on Summit http://www.summitracing.com/parts/SC...5BIE/?rtype=10
It's a complete forged kit with 2 valve relief pistons and what not. I will also get a le2 or le3 head job done with a custom cam grind. It won't see any boost just all motor. I'm using head gasket part number Mr. Gasket 5716.
I've built many stock motors but not one like this. I just need to know if this is a good direction or if I sould keep looking.
Budget doesn't matter It's gonna take me a year to get this all done anyway.
Thanks guys.
Old Aug 5, 2011 | 05:31 AM
Guest47904's Avatar
Guest
Maybe a slightly different approach is needed
Maybe you could consider one that is already put together on the bottom end?
http://www.golenengineservice.com/en...p-short-block/
These folks obviously don't want to sell many SB's
http://www.victoryracingengines.com/...TX&BLOCK=SHORT
No price
http://www.southeastperformance.com/...ducts_id=10519
Picture is obviously wrong
http://high-performance-engines.com/...duct_Code=SP33
Old Aug 5, 2011 | 04:52 PM
mrmint69's Avatar
Re: So.... got me in trouble advice?
Would love to here what you fine when you tear it down. I have heard stories about missing tools left in the motor and do all sorts of fun things. Could be anything that caused your problem.
Old Aug 5, 2011 | 05:12 PM
96capricemgr's Avatar
The Victor gaskets are the only part you listed I would use.
I would not use Golen and the last two links are low compression suggesting LT1 ignorance.
The VRE stuff I might consider the "racer series" with Compstar components. Price is maybe a little high for not listing main cap upgrades, but no core and good parts. The lesson you should have learned here is it is cheaper to do things right than to do things cheap.
You say budget doesn't matter but what I see is someone choosing everything on price. You spend a little more on quality parts and you will be further ahead.
David Dempsey
Mar 12, 2016 12:42 AM
Ericksd
Jan 20, 2016 06:07 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
