so aparently my car thinks its a corvette
Old Nov 2, 2003 | 03:43 PM
anasazi's Avatar
i just downloaded my programming today and to my amazement the biggest thing that jumps out at me is that the PCM thinks its a corvette with P285 55 17 tires and a 3.08 rear gear ratio...
WTF
i thought my car was stock? aparently not! i'm looking for a stock program now to compair the MAF tables because i'm almost sure they're messed up causing my problems.
just goes to show you never know what your going to get when you buy a used car, and i've had this thing for over a year.
Old Nov 2, 2003 | 03:48 PM
kingman109's Avatar
hmmm... interesting
Old Nov 2, 2003 | 04:45 PM
anasazi's Avatar
http://anasazi.sytes.net/carscans/co..._in_camaro.jpg
anyoen know where i can find some stock MAF tables to reference off of?
Old Nov 2, 2003 | 05:50 PM
Shockwave's Avatar
Lounge Moderator
Moving to LT1 Tech.
Craig
Old Nov 2, 2003 | 06:04 PM
carlos64030's Avatar
Re: so aparently my car thinks its a corvette
WTF
Ummm...there's no such thing as a 285-55-17 tire. On certain model years of the Corvette, the tire sizes were 285-40-17 rear, and 255-45-17 front.
Old Nov 2, 2003 | 06:19 PM
anasazi's Avatar
Re: Re: so aparently my car thinks its a corvette
yep my bad, i just checked again and its 285-40-17
was going off of memory
Old Nov 2, 2003 | 06:47 PM
Here is a screen shot of a stock MAF table for 1995 A4 Z28.
Your speedometer calibration window looks just like mine. The current values are what you have now. The new values are based on what you input into the top, left column and then click calculate (you will then see new values change).
What you see initially on the screen is just the default values the program throws in. It does not mean that is what your car is (except for the "current values").
Old Nov 2, 2003 | 07:22 PM
anasazi's Avatar
my MAF tables look exactly like that...
argh wtf ? why does my car run perfectly with the MAF unplugged but with the MAF plugged in it runs rich? the MAF doesn't seem slow or wrong according to the logs.
CaRParts102
Dec 6, 2014 08:45 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
