Smog Pump Delete Kit?
Old Feb 4, 2006 | 07:31 AM
jonesy's Avatar
have a 94 Z and want to delete smog pump , where can I get a kit or what if any are my options.
thx,
jonesy
Old Feb 4, 2006 | 07:38 AM
69z-28's Avatar
Re: Smog Pump Delete Kit?
i think you just take everything out. if you have stock manifolds cap off the AIR lines on top and then remove all the rubber/hard lines and unbolt the pump itself. then unplug anything connected to it and there is one line that goes to the intake you must cap off.
Old Feb 4, 2006 | 07:48 AM
Jeff95TA's Avatar
Who sells vacuum caps? Local auto parts?
Old Feb 4, 2006 | 11:09 AM
Amped96's Avatar
There is one line that you will probably have to cut to remove, but other than that...its simple. The only gains you'll get will be weight and extra space in the engine bay (worth it to me) because the pump is just electric.
Old Feb 4, 2006 | 11:48 AM
If you have the stock manifolds you will need two M22-1.5 oil drain plugs to plug the holes. If you have headers with AIR connections, you might need those same plugs, or caps for some header brands.
After you remove the air supply line from the intake ducting, you need a 5/8" vacuum cap. Its a common item at an auto parts store.
Old Feb 4, 2006 | 02:08 PM
jonesy's Avatar
thx all
Old Feb 7, 2006 | 09:00 AM
WhiteSSP's Avatar
Sorry for bringing this back, but is the air supply line the one that goes to the portion of the ducting right before the MAF?
Old Feb 7, 2006 | 09:11 AM
RICEFEDZ28's Avatar
Yes Icapped and zip tied mine.
Old Jun 28, 2013 | 11:24 AM
flhr's Avatar
I have a 1994 Z28 and wish to remove and reprogram the PCM to eliminate the pump and PCM codes...
What about the "Check Engine" light & the fans staying on...
Thank you for your help!!!!
Old Jun 28, 2013 | 11:37 AM
In OBD-I (93-95) all you need to do is unplug the harness connector from the pump, and make sure there is a good fuse in the circuit. It will not set a code, not turn on SES light, not turn on the fans if you do it that way. No programming necessary.
Old Jun 28, 2013 | 02:00 PM
flhr's Avatar
I will try this...
Thank you very MUCH!!!!
Old Jul 7, 2013 | 09:29 PM
1FST4GEN's Avatar
What do you mean by good fuse in the circuit?? Sorry for the Newby question!
Old Jul 7, 2013 | 10:47 PM
The fuse for the AIR pump in the under hood fuse/relay panel. It has to be good. The relay also needs to be there.
Old Aug 16, 2013 | 12:44 AM
cole3714's Avatar
What about OBD-II? Does it need programmed?
Old Aug 16, 2013 | 08:54 AM
OBD-II will likely complain. Reprogramming is necessary to keep the code away.
armedtrigger
Feb 24, 2015 08:30 PM
alphaauto
Jan 23, 2015 07:42 AM
ANDYZ28
Dec 29, 2014 09:13 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
