Smog/air pump removing.. alt and radiator reloaction.. then turbo
Old Feb 4, 2006 | 02:38 PM
LT1-TA's Avatar
I want to move everythingt out of the way so i can take the manifolds off a early 90's truck and put them on backwards (have the outlet port towards the front). This will mkae it easy to setup my turbo from there. THe biggest problem with this is two - three things.
ONE. There is there alternater on the pass side in the way.
TWO. Intake will be too close on the drivers side
THREE. For a front mount turbo setup and to make it fit easy, i will have to geta new smaller radiator and move the location...
So i need all the suggestions i can get. THis is a daily driven car so nothing too radical. I need PS and if AT ALL POSSIBLE, a/c would be nice.
So i want to get a griffin radiator and cut a bit out and mount it up like this.. any tips on this? anyone here done this? I need all the help i can get. Though i think this is going to be easier than figuring out the alt thing.
[/QUOTE]
Old Feb 4, 2006 | 03:22 PM
Dave89IROC's Avatar
Re: Smog/air pump removing.. alt and radiator reloaction.. then turbo
huh?
I'm confused, you have pics of two different setups, pn 2 different engines(lt1 and ls1), the the red car wouldn't work like that, you have no room for the throttle body.........
Old Feb 4, 2006 | 03:57 PM
LT1-TA's Avatar
Originally Posted by Dave89IROC
huh?
those pictures are up to show where i want the radiator... nothing else...
as for alternater relocation, i have no idea what to do there and was looking for someones help/suggestions.
edit: AND YES THE RED CAR WILL WORK..... he is doing something similar to this.
Old Feb 4, 2006 | 04:35 PM
95_MuLLeT_LT1's Avatar
MMMMMMMM, Steele Reserve!!!!!! Sorry, ill shut up now.
Old Feb 4, 2006 | 04:36 PM
Dave89IROC's Avatar
what are you asking then, if you know how you want to mount the rad?
Old Feb 4, 2006 | 05:15 PM
LT1-TA's Avatar
I NEED HELP MAJORLY WIT HTHE ALT RELOCATION!!!! The rad thing i just was looking for some helpful tips from people who have done it...
The main purpose of the thread is around the damn alt... i need it out of the way so i can run exhaust where it is...
Old Feb 4, 2006 | 07:14 PM
Chrisbequick's Avatar
Are you sure you will have to relocate the alternator? I used Vortec truck headers and they clear everything but the A/C compressor on the stock bracketry.
-Chris
Old Feb 4, 2006 | 08:44 PM
LT1-TA's Avatar
-Chris
humm... well i was going to use the manifolds not the headers... but that sounds likea good idea... what headers did you use (part number??)....
Im going to check out your pictures... im just going with a real real little t-61 for 6 psi or so on the stock motor. I plan on going to something like a T76 GTS or more after i get the forged bottom end.
If I don't fully comprehend what you have done on your car, would you be willing to snap a couple pictures for me? (or do you want to keep that **** top secret like everyone else.. lol..)
THanks a lot... your pictures are already a ton of help.
Old Feb 5, 2006 | 12:12 PM
LT1-TA's Avatar
Ttt Bump!
ok... i do have one question about mounting the headers backwards like that.. do the exhaust ports all line up fine and fit the ports right? this is a queston someone asked me, and i wouldn't know (though im assuming they do)...
Old Feb 5, 2006 | 05:17 PM
LT1-TA's Avatar
-Chris
so are these the headers you are using? These look the most like the ones from you pictures... if not could you point me in the right direction?
http://www.jegs.com/webapp/wcs/store...ctDisplayPopup
Old Feb 5, 2006 | 11:11 PM
LT1-TA's Avatar
after gazin through you pictures im almost positive this is right.... you dont happen to have some pics of the pass side do you?
Old Feb 6, 2006 | 09:54 PM
LT1-TA's Avatar
can someone move this to the foreced inductions section? It is not getting ANY response here..
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Gtpguy
Jan 26, 2015 04:50 PM
