smells like a caramel inside...
Old Feb 20, 2003 | 11:31 PM
  #31
QUICK305's Avatar
Just another suggestion, but if you don't want to spend $120 for a GM heater core, you can buy one from Autozone for $60. Some parts I buy are only GM, but I figured I'd try the Autozone heater core, and it worked fine.
The heater core is actually pretty easy to replace...If you plan on keeping your car for more than a few months, then you should think about starting to work on the car yourself. You WILL have more broken parts, and labor gets expensive real quick.
Old Feb 20, 2003 | 11:37 PM
  #32
TMDZ28's Avatar
$60 in autozone?? are you for real?? if it's only $60 i can do it by myself......well, i'll try to bypass it like our doc here said. then in a couple of weeks, i'll buy a heater core from autozone...thanks dude
Old Feb 20, 2003 | 11:44 PM
  #33
TMDZ28's Avatar
Originally posted by Wild1
If you are going to the cruise this weekend. I'll bring a radiator pressurizer to confirm the location of the leak. It sounds like the heater but it good to verify the issue. By loosing pressure (small or large) you are effectively dropping the pressure in the system. By dropping the pressure, you are lowering the boiling point. That is bad.
When the boiling point is lowered, you will get bubbles from the boiling coolant which create hot spots. Those spots are localized areas which the coolant cannot touch because the air is blocking the coolant from the surface. That can cause heat stresses and cracks. Ultimately, it can warp not only the aluminum cyl. heads but can also create hot spots on the cylinder walls.
Let's not get into any trouble here. I will bring the tester. Call me to remind me on Saturday, my number is in the SCCC directory.
Personally, I would get a plumbing pipe with the diameter that is equal to the inner diameter of the heater hose with two clamps. I wouldn't want to obstruct the flow with bolts. Either way, the idea is to bypass the heater completely. Again, I'd go like the TB bypass and get 1 pipe (2-3 inches) and 2 hose clamps, versus 2 block off bolts.
thanks a lot Wild1, i'll remind you again on saturday...btw i tried to call you last month but i got your office phone number....so what should i do??
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
