Smart guys only 95 Z28 Camaro(AutoXRay)
Old Oct 9, 2003 | 11:07 PM
Fred Jeter's Avatar
Exclamation Smart guys only 95 Z28 Camaro(AutoXRay)
I purchased a brand new AutoXray Code Reader from O'Reilly Auto Parts Company and it would not read the codes on my car. I have a 95 Z28 Camaro that i bought new; however, its an OBDI car with a OBDII ECM/PCM receptacle underneath the steering wheel. Do anyone know of a code reader that will work on my car?
Old Oct 9, 2003 | 11:10 PM
Did you get the special cable that works with the 1995 OBD-I pcm and OBD-II type DLC connector? It should work fine, that is if you got an OBD-I scanner.
Old Oct 9, 2003 | 11:36 PM
95loveaffair's Avatar
Take that scanner back and check out Ram Chargers. They have a "scanmaster" which will read your codes.
Old Oct 9, 2003 | 11:48 PM
The Xray will work. I've used one for about 5 years on my 1995.
Old Oct 10, 2003 | 10:21 AM
multicar's Avatar
Ditto, it should work. I had the original and had it upgraded to ODB-II for $75. Now autoxray has an upgrade to CAN supported vehicles for $99. Might want to check their website for their tech support number and specials if interested.
Doug
Old Oct 10, 2003 | 10:39 AM
MaddHatter's Avatar
What did the AutoX cost ya from OR?
Old Oct 10, 2003 | 10:58 AM
Typical pricing
Old Oct 14, 2003 | 04:58 PM
yorkie's Avatar
all you need is two jumper wires, I have a 1995 I know...
ttt
Old Oct 14, 2003 | 05:03 PM
naztyz28's Avatar
the two jumper wires will not work on a obd1 i have a 94 and know they dont .
Old Oct 14, 2003 | 05:08 PM
yorkie's Avatar
a 1995 has a obd2 connector...
but has the obd1 profile, the jumper method works fine I have a autoxray and it is hooked up this way.
Old Oct 14, 2003 | 05:35 PM
Mtrhds94Z's Avatar
I believe yorkie means jumping the appropriate connectors in the OBDII type connector to the OBDI style cable, not the 'paper clip' jumping method..[which doesn't work for 94+]
Old Oct 14, 2003 | 05:36 PM
yorkie's Avatar
yes absolutely correct.
NOT the paperclip method.
Old Oct 14, 2003 | 06:46 PM
Cory1994z28's Avatar
the scanners seem to get pretty expensive.... how much better is the 500 dollar one vs $200 one
Old Oct 14, 2003 | 08:10 PM
naztyz28's Avatar
ah i see my B.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
mspennyhughes
Nov 28, 2014 03:22 PM
grendal
Apr 15, 2010 05:20 PM
