Small oil leak
Old Jun 26, 2006 | 07:53 PM
tfs95z28's Avatar
Small oil leak
When looking at the front of the motor, what is the pulley that is to the immediate left of the tensioner?
Whatever is connected to that appears to be leaking a little bit of oil. Probably about a couple of drops every 2-3 days or so. I know it isnt much, but I HATE OIL LEAKS... Any thoughts???
Old Jun 26, 2006 | 09:15 PM
OBE1 95Z28's Avatar
Re: Small oil leak
That's your air conditioning compressor.
Old Jun 26, 2006 | 09:23 PM
Dave89IROC's Avatar
Re: Small oil leak
yup
dead center is the crank, next one left is the tensioner, next one left is A/C comp., above that is the P/S, above that is the alt.
Old Jun 26, 2006 | 09:41 PM
tfs95z28's Avatar
Re: Small oil leak
i knew i should have removed all of that crap... i never use the a/c... hmmm, would oil be leaking from there or is it coming from some place else? From what i can see (which isnt a whole lot) nothing above it seems to be leaking...
And if it is from that... what needs to be replaced? Is this a common issue?
Old Jun 27, 2006 | 07:22 AM
tfs95z28's Avatar
Re: Small oil leak
anybody?
Old Jun 27, 2006 | 09:34 AM
OBE1 95Z28's Avatar
Re: Small oil leak
You're AC system does contain oil. The "oil" also could be power steering fluid as the hoses/reservoir for the power steering are located just above the AC compressor.
Old Jun 27, 2006 | 11:15 AM
tfs95z28's Avatar
Re: Small oil leak
yeah, those fluids look the same, ill have to see if it is coming from above the AC compressor or not... thanks.
I dont know which I would rather have leaking, sucks either way.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
