I wish someone would have told me...
Old Jun 26, 2006 | 06:02 PM
hollywoodZ28's Avatar
that my lt1 check engine light had a mind of its own and likes to play games with me!
After remedying the maf codes,random misfire codes,car runs sweet for 20 minutes and then throws another code..this time its a p0151 o2sensor circuit low volts, bank 2 sensor 1 ..... what on earth do I have to do and who do I have to pay one final time to rid myself of these check engine codes!??!! I have had her in about 5 different shops, spent almost 5000.00 in tune ups...over the years only to have the car's check engine lights stay on.
I would even take it back to the shop and just got tired of the return of the code one day after I leave the shop. Its really beginning to become more trouble then its worth, I have spent sick amounts of money and my car refuses to run at its optimal level for longer than a day.
Too bad I did not find this forum until recently, maybe I could have found someone who knows there LT1 Sh*t and would have her purring for me by now! Its been 4 years already! I am not giving up just venting, hopefully someone can advise! Thanks!
Old Jun 26, 2006 | 06:15 PM
Heatmaker's Avatar
Advanced Member
Re: I wish someone would have told me...
I"m glad you found this forum too, before you wnet and brought some Edelbrock heads.
Old Jun 26, 2006 | 06:18 PM
Mike96z's Avatar
It's the o2's. If your o2's are bad it will throw alot of things off and then it will throw multiple codes. I had the same prob, MAF and o2 codes at the same time and it was just the o2's.
Old Jun 26, 2006 | 06:19 PM
So stay away from the edelbrock heads then? I see the good reccomendations about the Le2 package maybe I will shift my attention in that direction for heads and cam!
Old Jun 26, 2006 | 06:21 PM
Thanks Mike96z and Heatmaker for the heads up, so I guess I will have to replace the o2's then. Ok will do that and keep my fingers crossed.
Old Jun 26, 2006 | 06:23 PM
indirocz28's Avatar
A guy i know is getting ready to sell his LT4 hot cam
and a 9" 3000 vigilante stall...
Old Jun 27, 2006 | 11:22 AM
The code sets when the O2 sensor voltage falls beow 200mV and stays there. Could be a faulty sensor, or something like an exhaust leak pouring air into the exhaust. Swap the pre-cat O2 sensors side to side. If the problem follows the sensor (P0151 changes to P0131) its definitely a sensor problem. If the code stays on the passenger side, its not the sensor, its something external causing the sensor to read low.
drt
Sep 27, 2015 04:39 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
heus
Sep 8, 2015 12:01 PM
WPHIG2
Aug 27, 2015 06:37 AM
Boss002
Jul 24, 2015 10:47 AM
