sluggish while cruising
Old Mar 27, 2013 | 11:11 PM
Chet1185's Avatar
Camaro after the new Trans, while cruising if I give it a little gas it like Boggs down and won't downshift right away. Other than that it drives great. Any ideas
Posted from Camaroz28.com App for Android
Old Mar 28, 2013 | 01:21 AM
slick1hunting's Avatar
Not too familiar with automatics but might see how she does manually shifting down as well as cruising it in the gear she would shift down to. Given the motor isnt sluggish its probably in the tune for the transmission would be my guess as it may need tweeked from what your old one was set at.
Old Mar 28, 2013 | 03:05 AM
Chet1185's Avatar
It is the Trans that was in my TA, fully rebuilt with the valve body out of the Camaro.
Old Apr 2, 2013 | 01:11 PM
Chet1185's Avatar
Could the torque converter be to low of a stall speed?
Old Apr 3, 2013 | 11:35 PM
divineprime's Avatar
Re: sluggish while cruising
Sounds a little like throttle position sensor issue. You can rule that out with a quick voltage check.
Old Apr 4, 2013 | 03:04 AM
Chet1185's Avatar
Ok cool,.I believe I still have my cable and software to watch the sensor.
Old Apr 4, 2013 | 06:46 AM
redline9570's Avatar
did you put trans fluid in the converter?
Old Apr 4, 2013 | 07:35 AM
Chet1185's Avatar
Sure did. I drive the car everyday with no issues just doesn't want to downshift right away and will bogg down for a little then kick down. I'm going to swap the tps from my TA to this engine see if there's any difference.
The converter is new just don't know if the stall is to low, not sure how it would act if so.
IndyZman
Oct 22, 2015 02:17 PM
kandied91z
Sep 30, 2015 11:43 PM
MDZ28
11
Sep 24, 2015 09:15 AM
meissen
Aug 11, 2015 06:05 AM
