slp shorties
Old Sep 21, 2003 | 09:12 PM
polcat1p's Avatar
slp shorties
What kind of gains will they give me? I also just put on brand new MSD-8.5 wires and new plugs,will they be alright with the headers?I dont want to shell out for new if i dont have to. Thanks Chad
Old Sep 21, 2003 | 09:19 PM
Josh-'04 GTO's Avatar
Look for 10-15 rwhp from a shortie header install instead of stock manifolds.
You should be able to keep your current plug/wire setup. You may have to invest in some fire sleeve to protect a couple of the wires.
Old Sep 21, 2003 | 09:20 PM
RamAir95TA's Avatar
You may want to invest in a set of OTVC wires and looms, just to make sure you don't burn your new wires.
A good bet on any header install is .3 and 3mph.
Old Sep 21, 2003 | 09:22 PM
polcat1p's Avatar
Just wanted to add a mod that i can feel,with out spending alot.
Old Sep 21, 2003 | 09:23 PM
RamAir95TA's Avatar
Going fast is expensive. You're not going to find a whole lot of modifications that you can "feel" without spending some money in the process.
Old Sep 21, 2003 | 09:25 PM
What kind of work have you done to it already?
Old Sep 21, 2003 | 09:30 PM
polcat1p's Avatar
Mostly stock cia,gutted cat,160 tstat,hyper chip
Old Sep 21, 2003 | 09:36 PM
Z95m6's Avatar
headers was the only mod i did beside heads and cam where i felt a noticable SOTP feel. I love my SLP's i actually ran all my wires in the stock location except the third one back on the drivers side.
polcat1p's Avatar
Old Sep 21, 2003 | 11:34 PM
1982z28with18s's Avatar
I've got slp's and all my wires are in stock position and not burnt. Just make sure to do it right the 1st time.
Old Sep 22, 2003 | 02:54 AM
mickeyiz28's Avatar
ive burned my factory wire and 2 accels already with my headers, it is the same plug that keeps burning them, 3rd back on drivers side, it burned through the heat sleeves and the accell on the last one it burned
Old Sep 22, 2003 | 05:30 AM
magius231's Avatar
the #5 plug (third back on the drivers side ) is known to be harsh on plug wires because its so close. What I did on mine was I ran Bosch Platinum plugs (the original not the +4 or whatever) which are shorter than normal plugs. I have yet to burn a wire on any plug and I have no firesleeving or anythign anywhere. Just for the hell of it I threw the stock metal heat shield on the #5 plug wire boot as well, although its really not necessary (its really tough to get on too).
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
