slp shorties
slp shorties
What kind of gains will they give me? I also just put on brand new MSD-8.5 wires and new plugs,will they be alright with the headers?I dont want to shell out for new if i dont have to. Thanks Chad
Look for 10-15 rwhp from a shortie header install instead of stock manifolds.
You should be able to keep your current plug/wire setup. You may have to invest in some fire sleeve to protect a couple of the wires.
headers was the only mod i did beside heads and cam where i felt a noticable SOTP feel. I love my SLP's i actually ran all my wires in the stock location except the third one back on the drivers side.
ive burned my factory wire and 2 accels already with my headers, it is the same plug that keeps burning them, 3rd back on drivers side, it burned through the heat sleeves and the accell on the last one it burned
the #5 plug (third back on the drivers side
) is known to be harsh on plug wires because its so close. What I did on mine was I ran Bosch Platinum plugs (the original not the +4 or whatever) which are shorter than normal plugs. I have yet to burn a wire on any plug and I have no firesleeving or anythign anywhere. Just for the hell of it I threw the stock metal heat shield on the #5 plug wire boot as well, although its really not necessary (its really tough to get on too).
tommalcolm
Sep 11, 2015 03:39 PM
