SLP Shortie Header owners
Old Jan 15, 2004 | 05:55 AM
97ss497's Avatar
Question SLP Shortie Header owners
I'm buying Taylor Spiro's to install when I do my header install. I'm having a hard time deciding whether to get the stock routing wires or the OVC routing ones. Which is best for the SLP dual cat shorty?
Old Jan 15, 2004 | 07:29 AM
Josh-'04 GTO's Avatar
I've done it both ways, and prefer the OVC setup with the SLP headers on my '97. The OVC setup holds the wires firmly in place, so I haven't burned one wire yet. But I might not be the best example, since I only put 900 miles on my bird this year.
Old Jan 15, 2004 | 11:50 AM
97ss497's Avatar
Come on guys, help me out......
Old Jan 15, 2004 | 01:11 PM
BUBBA's Avatar
I just have the stock wires on my 97SS w/dual-cats.
Did get heater hose burned, but have since put some space between header and hose.
Haven't had any trouble yet with plug wires. Just make sure that they have some space and fire sleeves where needed.JMHO
OH...and my headers are coated.
Old Jan 15, 2004 | 01:14 PM
BUBBA's Avatar
Also: if those Taylors are larger than stock (which they don't need to be) you are probably going to have issues with routing anyway and therefore might consider OVC routing.
Old Jan 15, 2004 | 01:16 PM
Camaro_Maniac63's Avatar
I burnt a couple wires after installing the SLP shorties, but a little heat sleeving took care of that problem. But if you have the means to do OVC wires, do it. I have seen a TA with that burnt the passenger side of the engine compartment due to a fire caused by the wires touching the headers. Good luck.
Old Jan 15, 2004 | 11:21 PM
S.J.S.'s Avatar
I have SLP's and Taylor's. I ran them the same as where the stock ones were. Only burned 1 wire but that was my fault. I just wasn't paying attention. Stay with the stock routing, it'll be good.
Old Jan 16, 2004 | 12:31 AM
1982z28with18s's Avatar
Sounds exactly like me. I don't have any head sleeves/shields and I only burned the one wire which was my fault. I've not got probably 20k miles with them and no problems.
Old Jan 16, 2004 | 05:15 AM
magius231's Avatar
I went OVC, and I'm happy I did. Never burned a wire, and the wires are nice and tidy in the engine bay. Honestly, for the $100 I paid for it, well worth it.
Old Jan 16, 2004 | 06:30 AM
BlackDog's Avatar
I ran the wires over the cover for plugs 5&7 and for 6&8. Plug 5 will need a heat sleeve. For the other plugs I ran them under.
Old Jan 16, 2004 | 06:49 AM
zoso1959's Avatar
Thumbs up no burn
had the SLP Coated headers on this past summer, put on about 3000 miles and use the stock plug wiring and haven't burnt a wire yet..........................................
zoso
Old Jan 16, 2004 | 04:39 PM
Tires_Smokin's Avatar
The thing that sucks about stock location is that the wire loom behind the power steering steel hose is hecka space limited. My Taylor wires barely fit and I had to start from the top wire loom position and wedge my way front top to bottom. Dont start from the bottom of the loom.
Oh and another thing..I learned the hard way, if using stock route....leave that loom in place that's behind the power steering steel hose because if you take it out then your wires will be be loose & touch the steering pulley & possibly get caught in the serpentine belt. Even if you do keep the loom in there, zip tie it just in case. I had to spend alot of time zip tieing the heck out my wires and wedge it back form the pulley. Man I should of left that thing in. I wish I just went with OVC's but I couldnt figure out how to route them so I just stuck with stock location. One of these times I'll do the OVC.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
slocody
Feb 10, 2003 01:04 PM
turbo_Z
Aug 19, 2002 10:50 PM
